Cylinder 6 & 4 misfiring and lack of power
Old Aug 26, 2010 | 05:59 AM
AliSalim's Avatar
4th Gear
Talking
Originally Posted by don1
Hi,
I thought I would share some of my Disco 2 V8 issues and solutions with you...
Lack of Power...I was suffering from a lack of power up hill - it felt like a missfire...I consulted these forum pages and the comments seemed to suggest Plugs, Leads and Mass Air Flow Meter...
I changed the plugs and leads...I changed the leads without having to strip the intake off...just lie on top of the engine and feel...(I tried using a web cam on a lap top but could not see much) this took less than 1 hour. No real improvement...Just changed the MAF senso and the car is like a racing machine...all issues seem fixed...this leads me on to...
Auto Shifting Issues...I was convinced that the auto box was not changing up to top when it should...it would only shift up to top at approx. 2,500 RPM / 55MPH. Once there it would lock in top and then it would stay there even down to 1,300 RPM...I was convinced it should shift earlier if not under load. I serviced the box changing all the fluid twice and replacing the filter after removing the sump - this is an easy job and the sump removal, clean and filter change / refit only took 30 mins...No change to the shifting of the box in to top! I changed the MAF sensor (see above) and suddenly the box shifts better in all gears and finds top at lower revs and when not under load! For $120 from a LR dealer this change of MAF is a must - treat this item as a consumable - I will!
I hope these comments help.
Good news, I read the above thread & I ask a friend of mine to give me a new MAF
sensor to try it on. Now my disco is moving smooth like a silk.
Thanks all and special thanks to don1
cobbcj7
Oct 20, 2014 05:13 PM
LRScott
Mar 14, 2014 10:12 PM
wolfgang528
Defender
Dec 28, 2010 04:25 PM
skrams
Feb 16, 2007 03:25 PM
