Cylinder 7 Misfire 😎
Hey guys,
So yesterday after work I started up my disco and it was idling pretty rough and it threw a check engine light. I went to advanced auto and used their OBD scanner and it said there was a misfire with cylinder 7. Any advice to what I should be looking for, or checking out? I started with testing the fuses after make sure the spark plug was tight and the connection was secure (gotta start with the basics right?) , but that's all I had time to do so far. My brothers told me to check the spark plugs to see if they're fouled (which they probably are, my disco has ~235k miles, its still solid though) and then the wires. Just wanted some more input. Thanks!
Those are the same items I would check:
- HT leads... fully inserted onto spark plug and ignitor coil pack, check condition of leads for burns from laying on exhaust manifold. You can swap HT leads with cylinder 8 since they are the somewhat the same length to test out
- Spark plug... cracked ceramic, fouled/worn plug, too large of a spark gap. You can always swap out a good spark plug for the one on 7 and test out.
BTW... If cylinder #7 is giving you trouble and not cylinder #4, that tells me the coil pack is still good since 7 & 4 share the same single coil.
@The Deputy no not because of the misfire. I had a leak in the top rad hose where I'd have to fill up alotbut I got that fixed and it's not consuming any coolant... yet 😂
The amount will be minimal, if leaking internally into cylinder (at first) and may go unnoticed...especially...since you had another leak previously. Top it off and keep a good eye on level after several miles of driving time. You can also buy a tester that measure exhaust gasses in the coolant...or rent one...and this will take a lot of the guess work out of this (regarding head gasket).
But, if you are certain there is no issue with internal loss of anti-freeze. Justdo your basic diagnostics, looking over wiire and plug. Maybe swap a different wire into the equation. Also, running some injector cleaner through it won't hurt. Could be fuel related.
