Cylinder Misfires
Old Jul 13, 2025 | 04:46 AM
Extinct's Avatar
Originally Posted by JohnZo
To clarify, the wasted spark for 4 is cylinder 7 (not 3). Firing order 1-8-4-3-6-5-7-2. 4 and 3 are not on the same coil. Swapping the parts should cause the fault to follow, so that is more definite than trying new parts because a new part is not proven to be good yet, vs the part swapped in to the bad position. Hope this helps.
You are correct, however generally we are not concerned with testing the coil by swapping the wire, only the wire. #3 and 4 are the same length, that is the reason I recommended swapping them. Swapping coils left to right is the only way to test the coils definitively.
Old Jul 15, 2025 | 07:08 PM
TNDiscovery2's Avatar
Just removed #4 plug.  It has been in engine for a week or 2.  Should it look like this?
Gap is a little lower than the range that was specified. I believe 0.8 mm. I will check and post.
oh yeah replaced this plug with a new identical.
Still miss fire on #4.
Old Jul 15, 2025 | 07:13 PM
Thanks for all the help. I'll begin trying your suggestions.
Old Jul 15, 2025 | 07:25 PM
Checked the gap for the plug. It is 0.8 mm or 0.031
Old Jul 16, 2025 | 12:34 AM
JohnZo's Avatar
Spark plug insulator should not be so black, but not caused by small gap. After a couple weeks, the insulator should still be nearly white. While you are in there at the coils, be sure to double check the HT leads are all going to the correct plugs and coil terminals, and don't get confused by the numbers on the coils.
Old Aug 7, 2025 | 01:19 PM
can I just swap wires with 4 and 6? Much easier to get to.
Old Aug 7, 2025 | 11:33 PM
JohnZo's Avatar
So, the basic concept is to move the bad part to a different location, swapping it with a known good part. That way the misfire should move to a different location. It does not really matter which known good part is used, so long as they fit, in cases of multiple similar parts (like spark plug wires). The problem with swapping in a "new" part is that it could actually be bad, since it has not been proven good on the engine. That is why the method uses parts already on the engine. It is a disciplined approach, without shortcuts, that is guaranteed to find bad parts if closely followed.
RGI82
Apr 26, 2024 09:38 PM
kl7z
Aug 19, 2023 05:10 PM
LR03NJ
Feb 26, 2016 08:12 AM
Bryan H
Sep 3, 2011 10:42 AM
RealRitzcracker
Jul 12, 2010 10:57 PM
