Cylinders Heads Removed, How to Move Pistons
Old 07-23-2014 | 02:07 PM
walkingzach's Avatar
Default Cylinders Heads Removed, How to Move Pistons
how do i move the piston down now that i have the cylinder heads off?
i want to check the sleeve and see if there is any damage down in the block...
piston 3 is the cylinder i am trying to investigate.
Update:
Piston position before...
Crank Pulley:
This is what you will be rotating to raise/lower the pistons.
Location in Engine Bay:
Bolt Size = 24 mm
Position of Pistons after Rotating:
That is how you can rotate the pistons with the engine disassembled.
Old 07-23-2014 | 02:13 PM
acamato's Avatar
Socket & Ratchet or breaker bar on the crank pulley
Old 07-23-2014 | 02:20 PM
Racer X's Avatar
I'll save you a bit of trouble here.
Is that the only steam cleaned piston? If it is, then the block is likely cracked behind that sleeve.
Old 07-23-2014 | 02:30 PM
thats what i hear....
my thought is i've gotten this far, i might as well find out for sure
Old 07-24-2014 | 10:48 AM
updated original post with some images of how to do this
Old 07-24-2014 | 01:12 PM
5kcstq's Avatar
Could very well be a head gasket leak and not a cracked block/sleeve issue. What's the head gasket look like around that cylinder. Also, get the head checked for flatness.
Old 07-24-2014 | 01:19 PM
drowssap's Avatar
there is no water passage from the block to the center of the head only on the ends 1,8,2&7 "i" believe.
so if you have steam cleaned piston in the center of the head the coolant probably did not come from 1,2,7 or 8.
Old 07-24-2014 | 08:45 PM
RoverMasterTech's Avatar
You are in trouble. My tip for you is to put everything back together with some new head gaskets, do the inline thermo mod, drop 2 bottles of blue devil pour n go, 2 qts of coolant and the rest water. May god have mercy on your soul.
Old 07-25-2014 | 12:00 PM
Motorhead1's Avatar
lolx2
Old 07-26-2021 | 11:05 PM
Steven Hill's Avatar
5th Gear
Default Removed heads need help
Can anyone tell me how this happens or if this is the way it should look on cylinder 7 & 8. 2001 disco 2
Quick Reply: Cylinders Heads Removed, How to Move Pistons
