D1 bumper on a D2
Old Aug 4, 2011 | 10:14 PM
hunter's Avatar
Default D1 bumper on a D2
Anyone ever try to retro-fit?
Thanks,
Dave
Old Aug 4, 2011 | 10:48 PM
Camdisco24's Avatar
I've never seen it done, and IMO it would be nearly impossible because the DII is a couple inches wider than the DI.
Old Aug 5, 2011 | 05:22 PM
MNRover14's Avatar
4wd High
If you try, please post up some photos.
Thanks
Old Aug 6, 2011 | 06:09 AM
hilltoppersx's Avatar
what type of bumper? i have a D1 ARB on my D2. the D1 has 3 horizontal mounting holes while the D2 has 2. That third mounting hole is located behind a piece of angled frame support that the D1 doesnt have. So I had to trim the mounts on the ARB a couple inches so that they would butt up against the angled support. to make sure it doesnt go anywhere i used 1/2" grade 8 mil-spec ultra-non-corrosive bolts, nuts and washers.
Old Aug 6, 2011 | 09:00 PM
hunter's Avatar
Ed,
Now that is my kind of thinking. Not a big fan of the DII ARB offerings, but a retrofit from a D1 sounds ok.
I just want a metal bumper to take some knocks. The DII bumper is plastic crap.
Dave
Old Aug 6, 2011 | 09:01 PM
yloDiscoII's Avatar
That is great little nugget of info....the Craigslist search continues!
Old Aug 7, 2011 | 07:04 AM
the front two holes are perfectly aligned and the bumper fits great, you just need to make that trim. the D2 ARB's have a bolt that goes vertical so they each have 3. I have not had any problems with just the two bolts i used. This goes in reverse, you could fit a d2 bumper on a d1 but you will be missing the third hole. then you have to look at air bag vs non air bag compatiable. if you get an air bag compatiable ( i know this defeats the purpose) but i would weld the crush cans to the frame for extra support. if you look how you stock bumper mounts you will understand what i am talking about. when you do find a bumper make sure to use 1/2" grade 8 bolts, the 1/2" bolts fit nice and tight in there and are 30x stronger than the stock 3/8" grade 5 bolts it comes with.
Old Aug 7, 2011 | 11:33 AM
jafir's Avatar
When I installed my ARB, I had to drill the two vertical holes on both sections of frame, originally there is just horizontal mounting hardware.
Old Aug 7, 2011 | 03:29 PM
you are talking about installing a D2 bumper? the D2 ARB's have the vertical hole so you can mount there as well yes. The D1's don't have that. I mean you can easily add that if you wanted.
Old Aug 7, 2011 | 05:04 PM
jafir's Avatar
Yeah, when I installed the d2 arb bumper on my 03, the instructions have you drill holes for the vertical mounting hardware. They aren't there to start with.
goatman
Mar 30, 2020 08:54 PM
Frank4
Mar 31, 2012 04:30 PM
LRD2&ME
Nov 23, 2011 09:44 PM
kpl1228
Nov 20, 2010 11:05 PM
Jst4fun
Mar 14, 2010 10:08 PM
