d1 info
Old 06-16-2009, 06:12 PM
I know next to nothing about timing, took me years to get a date.
  #22
Old 06-16-2009, 07:40 PM
okdiscoguy's Avatar
Originally Posted by tweakrover
i'm hopeing that advancing the timing helps mine, all the sympoms point to that, overheating, poor acceleration, and poor gas milage.
use a light. If you get it too advanced, you will detonate and burn a cylinder.
Check between your radiator and evaporator. Over time crap builds up. If that doesn't help, get a laser thermometer and check the radiator all over for temp. Look for hot spots to see if it is flowing right. These babies have small tubes and can get clogged easily. Especially if someone put in stop leak to try to cure a leaky intake...
  #23
Old 06-16-2009, 08:55 PM
tweakrover's Avatar
i like the themometer idea, if i find that i doo have a clogged radiator what to do next?
  #24
Old 06-16-2009, 09:06 PM
Replace it.
www.roverlandparts.com
www.autosportsunlimited.com
1800radiator
If you do need a new one becareful when buying off of e-bay, one of our guys got burned, it was advertised as out of a low mile rear ended truck, it was actually crud filled and had a hole in it.
  #25
Old 06-16-2009, 10:12 PM
tweakrover's Avatar
well ill probly get to it this weekend, i've still got some other things ive got to get to like atf and diff fluid change. thanks
  #26
Old 06-17-2009, 03:27 PM
crainb45's Avatar
Originally Posted by spike555
i know next to nothing about timing, took me years to get a date.
roflmao
CantAffordaRover
Defender
12-07-2006 12:19 AM
rory2000
Off Topic
01-10-2006 03:03 PM
thalpo
08-08-2005 01:55 PM
95countylwb
07-14-2005 12:22 AM
neilp
01-03-2005 04:47 AM
Quick Reply: d1 info
