D1 Radio No Worky - Where To Start?
The radio in my 1998 hasn't worked since I bought it. It's the radio w/cassette and CD changer. By all appearances the radio powers and the functions appear to work: it will scan and lock onto FM stations, and you can go through all the bass/trebble, etc functions. Just no audio. Well, if ya turn the radio up all the way, you can faintly hear audio.Where to start. Is there a separate amplifier? If so, where is it located and is it fused separately?Also, might there be a radio function that I'm not aware of that is muting the audio?
Thanks in advance for suggestions.
Sounds like an issue with the amp.
The amp would allow the signal to pass through regardless of if it was working or not. Since you can hear the radio faintly, it suggests to me that the amp is not powered on and the reason the sound is faint at high volume is because the head unit does not have enough power to drive the speakers, only enough to produce minimal sound.
southfloridadiscoII
06-28-2009 11:03 PM
