d2 2002 wont go over 2500rpm
Old Aug 5, 2009 | 08:39 PM
cnissen73's Avatar
5th Gear
Default d2 2002 wont go over 2500rpm
I have a 02 d2 that has seen some mud and water this spring/summer. It runs but not over2500rpm or so. When I try to give it more gas it bogs down. At 1st I thought I just got everything so wet that i got water in the fuel. But i ran a can of SeaFoam thru it and it is better but not good would like to be able to go over 55mph. Thanks Chris
Old Aug 5, 2009 | 09:00 PM
roverguy7's Avatar
does it act the same in neutral as when in gear?
Old Aug 5, 2009 | 09:46 PM
Shift into neutral and try and rev the engine to 3000 rpm.
Old Aug 5, 2009 | 09:53 PM
AK Rover's Avatar
Sounds like a blockage somewhere in the fuel system or your fuel pump is failing. The engine isn't getting enough fuel to run at those high RPMs. I would lean toward the fuel pump on its way out.
I personally try to keep my RPMs under 2000 whenever possible to help with fuel mileage.
Old Aug 5, 2009 | 10:07 PM
cnissen73's Avatar
5th Gear
Default d2 wont go over 2500rpm
i just went out and reved it in neutral and i could get it up to 4grand but had to pump the gas to do it. if i just tried to floor it it starts to cut out. thanks chris ps is there any way it could be the cat. converter
Old Aug 6, 2009 | 12:01 AM
cnissen73's Avatar
5th Gear
i put it in neutral and it reved to 4grand but i had to pump to get it there if i just floor it it cuts out could it be the cat. convertor
Old Aug 6, 2009 | 07:02 AM
AK Rover's Avatar
Is there some reason you think the problem may be cat related? It doesn't sound to me like it is but I could be wrong.
Old Aug 6, 2009 | 03:38 PM
cnissen73's Avatar
5th Gear
Default 02 D2 wont run over 2500rpms
I have heard that the cat can go bad if it gets banged around. I dont think mine did to bad mostly mud and water around here. Can i try the throttle body clean out thats posted on here for the D1. Thanks Chris
Old Aug 6, 2009 | 03:41 PM
lipadj46's Avatar
How old are your wires and plugs? You are not getting any codes thrown?
Old Aug 6, 2009 | 07:02 PM
roverguy7's Avatar
it could easily be the cat, if your exhaust is restricted then itll cause some similar issues... however if it was just getting wet, i dont see it being the cat, take a look at em, see if theyre real banged up. ive seen mass air flows go bad cause the same thing too on these. got a vacuum gauge?
