d2 2002 wont go over 2500rpm
Old Aug 6, 2009 | 07:39 PM
Originally Posted by cnissen73
I have heard that the cat can go bad if it gets banged around. I dont think mine did to bad mostly mud and water around here. Can i try the throttle body clean out thats posted on here for the D1. Thanks Chris
Yes you can do the throttle body cleaning, this is good once a year maintenance for any car or truck.
Old Aug 6, 2009 | 09:09 PM
cnissen73's Avatar
5th Gear
Default 02 D2 wont go over 2500rpm
No vaccum gauge or code reader. Live in small South Dakota town with only three shops and none of them will touch it. Over an hour to a town with a import shop and that would be with it running right take 2hrs the it runs now. It started this while I was mudding. At 1st it died then when it fired up the service engine light was flashing and it would only idle ruff if i gave it any gas it would die. After a few minutes the light stopped flashing but was stil on and it seemed to come out of it but i was still on back roads and wasnt going very fast. It was when i hit the hiway and gave her some gas she died again and the light started flashing again. I limped her home and put the seafoam into my tank i had about a 1/4 left. I ran that thru and it seemed to help so i put in another 1/4 tank of gas and put a bottle of injector cleaner in. The service light is on but not flashing. The entire engine compartment was covered in mud thats why i was wondering if i could clean the throttle body like in the post for the D1, just spray a can of carb cleaner in it? Thanks Chris
Old Aug 6, 2009 | 09:15 PM
lipadj46's Avatar
You need to get the codes read. Any shop or auto parts store should read them for you in 30 seconds for free. You really need the codes. Along with the throttle body cleaning o an induction cleaning but until you get those codes we are kind of playing pin the tail.
SolbergFanBoi
Mar 5, 2012 07:05 PM
ctjawadisco2
Feb 19, 2009 02:39 AM
tryinthis2
May 22, 2008 09:35 AM
40ranger
Mar 19, 2008 05:11 PM
kinsella
Apr 21, 2007 10:21 AM
