d2 2002 wont go over 2500rpm
I have a 02 d2 that has seen some mud and water this spring/summer. It runs but not over2500rpm or so. When I try to give it more gas it bogs down. At 1st I thought I just got everything so wet that i got water in the fuel. But i ran a can of SeaFoam thru it and it is better but not good would like to be able to go over 55mph. Thanks Chris
it could easily be the cat, if your exhaust is restricted then itll cause some similar issues... however if it was just getting wet, i dont see it being the cat, take a look at em, see if theyre real banged up. ive seen mass air flows go bad cause the same thing too on these. got a vacuum gauge?
