D2 Air shock leak when below Freezing
I truly believe it's the Valve block where its leaking. When the weather is good everything works fine. It's when its too cold. How hard is to replace Valve body?
I can get fairly reasonable new valve body on ebay or Arnott for reasonable.
I have not found a write up on how to replace the Valve body. will appreciate if you have any suggestion since you mentioned you overhauled it.
