Air pump and cooling fan
Old Aug 28, 2013 | 04:50 PM
UtahExplorer's Avatar
Default Air pump and cooling fan
Greetings wise ones -
I have failed the safety and emissions testing for the second time. I replaced my brakes but failed on the "sec air pump" - I have no idea what this is. The technician stated it was something that helps with the emissions when the engine is started cold.
I notice that when I start my Disco in the morning there is a fairly loud whirring noise that stops after about a minute - is this what they are talking about?
The shop quoted me $478 plus labor - I can't find the part on rockauto.com.
I need some help. What is the story on the "sec. air pump"?
Old Aug 28, 2013 | 05:31 PM
Secondary air pump - normally runs at cold start, then from time while running sometimes as a functional test. Sounds like a hair dryer when failng, passenger side of engine. Reduces pollution
Old Aug 28, 2013 | 06:13 PM
Get the actual fault code numbers and get them to us so we can help you with this.
You can also buy used parts for a lot less money but need to know which ones are bad.
Old Aug 28, 2013 | 10:28 PM
jfall's Avatar
If you hear the whirring, then the pump is turning.
The pump is on the passenger's side on the firewall.
Looks like a fan motor.
Off of it is a black air hose which is about an inch thick.
That air hose goes to a pipe which is behind the engine and pinned against the firewall.
Make sure that the air hose is attached and not a break in that hose.
Old Aug 28, 2013 | 10:29 PM
jfall's Avatar
All that pump is - is really a little shop vac which is running when the engine is first turned on.
It injects air into the heads eventually.
0304Disco
Nov 7, 2012 03:11 PM
rover1978
Sep 26, 2009 09:05 PM
btp226
Engine & Internal
Oct 21, 2007 08:37 PM
igriego
Mar 14, 2007 01:53 PM
vonfonk
May 6, 2006 06:50 PM
