D2 alarm triggered and emobolised
Old Oct 16, 2014 | 08:52 AM
flabrit's Avatar
Default D2 alarm triggered and emobolised
Here's where I'm at...bought a 2001 DII with a bunch of mostly cosmetics problems was working through them and now the key does not start motor this morning. Gets stuck in ignition when I tried. If I unplug battery I can remove key but does same thing if I try again. Doors do lock and unlock with key (not all of them).
Here's how I got to this point...
Key fob hadn't worked since i got truck,
I locked truck with key and tried to open back door (which didn't lock...another issue) and set off alarm.
Turned alarm off with door lock.
Locked doors again and left for night.
Now in morning opened door with key, alarm light was fast flashing, went out and truck in emobolised. Alarm light flashes rapidly for a few seconds then goes out, lock activates with key but key sticks in ignition and will not start car.
Any ideas on just getting it to run with the key?...please!!
Old Oct 16, 2014 | 09:51 AM
jafir's Avatar
The alarm shouldn't have anything to do with removing the key. It sounds like an interlock problem. Maybe an XYZ switch out of adjustment. Normally on a NAS D2 you have to be in park to take the key out, IIRC.
Old Oct 16, 2014 | 11:09 AM
flabrit's Avatar
I was wondering about the key...if key is locked in ignition and only released when battery disconected you are saying this is nothing to do with alarm? Just want to be sure before I go that route. Thanks
Old Oct 16, 2014 | 11:42 AM
drowssap's Avatar
i do not believe the alarm would keep you from removing the key, but if your transmission is not reading park it will keep you from removing the key, is what he trying to tell you
Old Oct 16, 2014 | 12:07 PM
Dave03S's Avatar
Is Emobilising a new interweb thingy?
Old Oct 16, 2014 | 12:22 PM
flabrit's Avatar
Maybe I made it up lol?
Old Oct 16, 2014 | 12:24 PM
flabrit's Avatar
Got it, thanks, seems most plausable explanation. Going to crawl under there tonight and see whats going on.
Old Oct 16, 2014 | 12:46 PM
abran's Avatar
I was waiting for Landlover (the resident spelling police) to bust his chops, but you beat her to it!
Old Oct 16, 2014 | 01:29 PM
Dave03S's Avatar
no police here... all in good fun! Good luck!
Old Oct 17, 2014 | 10:14 AM
flabrit's Avatar
So I'm now dissemobolized Lol. Was the xyz switch ...wiggled and adjusted it a bit and I'm moving again. Going to pull it apart this weekend and clean and hope thats permenant fix. Thanks for help
