D2 Axle Service / Maintenance
Old Oct 18, 2009 | 03:56 PM
Rover_Hokie's Avatar
Default D2 Axle Service / Maintenance
I have taken care of the 60K mile service on my D2, but wondering what needs to be done to maintain the axles' lubrication, wheel bearings, etc.?
Old Oct 18, 2009 | 05:21 PM
As long as you have changed your gear oil, you are set, nothing else can or needs to be done other then greasing both you drive shafts.
Old Oct 18, 2009 | 05:38 PM
Axles are maintenance free except for the gear lube.
Old Oct 18, 2009 | 07:38 PM
So just need to do the lube on the drive shafts and change the diff gear lube and that is it?
Old Oct 19, 2009 | 08:32 AM
Yup. Thats it.
Depending on what type of gear lube you used, dino lube change it every 30k, full syn change it every 50k.
Lube your u-joints at EVERY oil change, check your gear lube level every other oil change (unless you have a leak) and all is good.
Do your transfer case the same time as the diffs.
Old Oct 19, 2009 | 09:52 AM
jycsalas's Avatar
Yeah the axles on DI and DII are very simple in terms of maintenance. DII's hubs are $400 each and are non serviceable.
(Another reason why Spike loves DI's)
Old Oct 19, 2009 | 04:38 PM
NiteTrain's Avatar
if you go off-roading in deep mud or muddy water changing the diff fluid every year is a good idea.
dshaefer
Aug 27, 2013 10:49 AM
LeakyDisco
Oct 25, 2012 01:38 AM
cationmoted
Oct 19, 2012 07:39 AM
Sarah2
LR2
Oct 5, 2011 10:17 AM
tsuami1
Feb 24, 2008 07:50 PM
