D2 Bump Stops
D2 Bump Stops
I have little bigger Tires. I have had few incidents of air suspension failure and the truck sits on the tire. Can't move the truck.
anyone Used Bump stops? I am assuming I can put generic bump stops (basically block of Rubber) anywhere just so I can move the truck for repairs.
Anyone used them? How many inches and where would I put them? Picture, location would help as well.
There are factory bump stops. You could probably replace them with another type or add some kind of spacer. Late model (circa 2020 or so) F250 rear bump stops are a bit longer and just take two bolts, would be pretty easy to make fit if you're handy. I'll be using a set I have when I SAS my gmt800 Chevy.
Fivespddisco
08-15-2017 09:22 AM
