D2 cdl activation with d1 linkage help
Old Jun 17, 2017 | 10:52 AM
Luckyjayb's Avatar
Default D2 cdl activation with d1 linkage help
Ok guys. Went n got a d1 cdl linkage from the local pull a part. Need some help on it. I'm figuring somebody has a good description or pictures on how to put it in. Thank in adavanve for the help.
Jay
Old Jun 17, 2017 | 11:56 AM
mollusc's Avatar
www.discovery2.co.uk/Factory Diff Lock
Old Jun 17, 2017 | 12:09 PM
Luckyjayb's Avatar
That's for the 04 or Ashcroft retrofit. I'm putting in the d1 linkage
Old Jun 17, 2017 | 12:29 PM
mollusc's Avatar
That's the guide I used when I put in my D1 linkage. The mounting holes on top of the T-case are there for your new shifter. My only recommendation is to put some Loc-Tite on the splines of the new shifter mechanism so that the linkage doesn't slip off the end during use.
Old Jun 17, 2017 | 01:30 PM
Friday Night Disco's Avatar
Glad to see panty dropper can keep up with Tricky Dick on the trails now!!
before you button things up check to see if you are comfortable with the lever position. Other than that, I can't provide anything else..
fyi just got back from the mountains
Old Jun 17, 2017 | 08:52 PM
Luckyjayb's Avatar
Got it all done and buttoned up and working like a champ. The panty dropper can keep up now and will be even better when I get the slabs from abran!!
Old Jun 17, 2017 | 09:37 PM
abran's Avatar
got the correct one in the mail today just before cut off.
Old Jun 17, 2017 | 11:15 PM
Luckyjayb's Avatar
Sweet. Thanks again abran
Old Jun 18, 2017 | 10:57 AM
Mskembo's Avatar
We absolutely have the best sources on here!
Old Jun 20, 2017 | 11:12 AM
I installed my CDL sticker so now I am 100% legit.
I thought of a CDL sticker for Panty Dropper
