D2 coolant bleed question
Old Jan 25, 2010 | 01:50 PM
salve7's Avatar
Default D2 coolant bleed question
I was just bleeding the air out of my D2 and couldn't get anything to come out of the bleed screw before I started the engine. Everything else went like clockwork as I followed the sticky. Why didn't anything come out? Should I have left it off until after I started the engine? Thanks for any help!
Old Jan 25, 2010 | 04:14 PM
lipadj46's Avatar
Did you take the tank out of the clips and raise it up on the battery cover?
Old Jan 26, 2010 | 01:03 PM
salve7's Avatar
Nope, I just followed spikes sticky. I wasn't having any problems but my coolant ran a little low so I thought I would be better safe than sorry.
Old Jan 26, 2010 | 01:07 PM
bikeG976's Avatar
Put bleed screw back on before starting engine - i forgot once - HUGE MESS! Keep filling tank slowly, it will eventually come out, I thought I was doing something wrong the first time as it wasnt coming out, just keep filling, it will.
Old Jan 26, 2010 | 01:09 PM
salve7's Avatar
I filled it past the high mark... I thought if I put more in it would just pour over the sides.
Old Jan 26, 2010 | 01:48 PM
lipadj46's Avatar
Open the bleed screw, pull the expansion tank off of its clips and raise it up and balance it on the edge of the battery box. This really is the best way to do it becasue if you look the expansion tank is about level with the engine and you will have trouble getting all the air out. Once you have it raised coolant should come out of the bleed screw hole. I flushed the coolant on my stepbrother's 95 taurus. They have the tank above the engine and radiator and are self bleeding, pretty easy.
Old Jan 26, 2010 | 01:52 PM
salve7's Avatar
Ok will do. I guess there is only one hose I should disconnect before raising said tank?
Old Jan 26, 2010 | 02:40 PM
lipadj46's Avatar
You do not need to disconnect any hoses it is made to be taken out for this purpose. Just pull it out of the clips and kind of guide the bottom hose between any obstructions. You will see what I mean.
Old Jan 26, 2010 | 03:00 PM
salve7's Avatar
sweet. I will give it a try.
JavaDiscoII
May 29, 2010 04:33 PM
03discoman
May 9, 2010 09:46 PM
christianmotox
Mar 12, 2010 10:31 AM
JAC
Oct 21, 2009 10:40 PM
JAC
Oct 1, 2009 04:02 PM
