D2 ECU waterproofing
I'm still not done. I replaced them both to get the thing to run, and now I'm just slowly working on all the little things so I can either drive it or sell it. I think my problems were caused by sun roof leaks, so I need to check that out too. Currently I've got a misfire that's more important, because the thing is parked inside. I've just been too busy with work to work on it much. After replacing the BCU, my keyless remote stopped working of course, but just last week a kind soul on this forum got me the code from land rover.
did the hawkeye then tell the ecm to adjust the odo to the correct mileage? or the ecu and bcm were then synced with the odo current mileage? just curious becuase i had to change consoles because the idiot PO broke the 3 amigo LED's off... the hawkeye would be an expensive fix but at least i would know there is a way to do it. the dealer said the only way to do it is to buy a new console because the t4 can't do it with a console that has mileage recorded on it, it's a way of protecting people from turning back the odometer.
Well the hawkeye just turns off the check, it doesn't actually sync anything. If I turn the check back on, it blinks again. But the dealer should be able to sync used stuff... I think it defaults to the BCU, or maybe it was if uses the item with the highest mileage was what some of the people that have used it were saying.
Anyway, I think someone was saying the mileage was in the BCU, not the ECM, so that you can swap the ECM and not have a blinking ODO. I think.
