D2 Flasher Relay Location
Old Feb 25, 2010 | 01:56 PM
Hayne's Avatar
Default D2 Flasher Relay Location
Hi, I have just bought a 1999 Disco2 TD5 and tried changing a front indicator bulb today. I put the new bulb in and tried the indicator stalk and nothing. None of the indicators worked. So, I took the bulb out and found that the two contacts had shorted together. Even with the contact apart, none of the indicators work. The other indicators worked fine before I put the bulb in.
I am assuming I have burnt out the flasher relay unit. Does anyone know where it is located? Or any ideas what else I might have damaged.
Cheers.
bleizit
Jun 24, 2020 04:03 AM
RicketyTick
Jun 24, 2014 06:58 PM
s10lowrider1994
Oct 6, 2011 01:22 AM
Roveroh
Aug 7, 2008 09:42 AM
Yetielliott
Mar 31, 2005 01:41 PM
