D2 Front Propshaft
I was driving tonight and heard a sound coming from under my Disco. I got home, checked all the bushings and they seemed OK. Then I looked at my front drive shaft and it looked ready to fall apart. The UJs were a lot hotter than the rear drive shaft's (those were actually cool). I never changed the front drive shaft so this is the problematic original.
Any recommendations for a new drive shaft? How hard is it to rebuild myself? My truck is stock and I'm looking for something affordable.
Thanks.
2004 Discovery II SE Black on Black
Thanks.
Just saw this on Amazon. Is it any good?
Never seen that one before, but it might be OK. Most guys looking to go cheap get this one from Lucky 8.
Yea, should work no problem. The D2 driveshafts lengthen and shorten just a little bit (slip joint in the middle). If you want to double check, just call Lucky 8 in the morning. Tell Erik or Justin (whichever you talk to) that you're from the forum and they'll probably give you a forum discount too.
