D2 Front & Rear ABS Sensor Difference:
Old May 28, 2017 | 08:42 PM
Best4x4's Avatar
Default D2 Front & Rear ABS Sensor Difference:
I did a bit of wheeling today and my RR ABS sensor tore apart and crumbled at the connector (sensor side). I have a set of spare front D2 ABS sensors, but I just wanted to check and see if I can use the D2 front ABS sensors in the rear of my D2.
If not I'll probably look into some replacements and extensions.
Old May 28, 2017 | 09:41 PM
briancbev's Avatar
Tore the sensor apart? Wow. How does one to that? In any event, because the hubs for the D2 are the same for the front and the back - except that the "front" hubs have longer sensor wires - I would not think this would be problem. Admittedly, I've never pulled the sensor out of the hub, but I put "front" hubs on the back several years and several thousands of miles ago with no problems (just coiled the extra wire out of the way).
Old May 28, 2017 | 10:07 PM
Best4x4's Avatar
It failed right at the plug between the D2's wiring & the actual sensor wiring (old original sensor wiring vs new one piece back to the SLABS unit). It completely crumbled. I flexed a little and I got the 3 amigos instantly. I hooked up my LRII Scanner real fast to pin point the fault. Listed RR sensor failure and sure enough it was blown to bits.
I've flexed before with no issues whatsoever so I'm really thinking it was just old and brittle and any little tension just made it crumble to bits.
If the fronts will work that'll be a sweet deal as the extra length will leave me more slack for future flexing.
I just did a trail fix and spliced the wires together and the 3 amigos never came back on but I am not gonna leave it rigged like that.
Old May 29, 2017 | 09:12 AM
Alex_M's Avatar
I've got fronts on my rear. They're a few inches longer and worked perfectly before my slabs got soaked because of a leak below my windshield.
Old May 29, 2017 | 11:45 AM
Best4x4's Avatar
Yeah I just finished installing it. I just cut off the extra rubber sleeves I didn't need and routed it so the connector sits up on the frame rail with plenty of slack. Cheap and free Rear ABS extensions right there.
RITTER
Aug 24, 2012 03:16 PM
wolfgang528
Defender
Dec 28, 2010 04:25 PM
Spencerfitch
Aug 19, 2010 06:11 PM
rirover
Jul 7, 2006 07:22 PM
