d2 head gasket- can see failure?
Old Nov 19, 2019 | 09:13 AM
Jason Feuerstein's Avatar
Originally Posted by newworld
update: no impression markings on bottom of head gasket from slipped liners. the metal rings on gasket are smooth and all there for all cylinders on left bank.
but i do have that tapping noise chronic...so maybe now im thinking oil pump gears and bearings.
before i tore apart engine i forgot to do an oil pressure test...but i never got low oil pressure light 6-7 psi. so it must be above that.
Check to make sure you don't have a stuck lifter or a worn out cam lobe.
Old Nov 19, 2019 | 06:44 PM
Extinct's Avatar
Post pics
Old Nov 20, 2019 | 11:20 PM
RossN99's Avatar
Did you have any blue smoke while driving the truck? Could low compression in 5 be worn rings on that cylinder? If so could you fill that cylinder with water to see if it leaks out to test the rings?
Old Nov 21, 2019 | 07:30 AM
Extinct's Avatar
Whatever you do - do not put water in the cylinder. If you want to check if it is a ring problem, squirt some oil in the spark plug hole and rotate the engine a few revolutions, then recheck the compression. If it increases you have a ring or cylinder problem. Never put water in a cylinder.
Old Nov 21, 2020 | 06:25 PM
Extinct's Avatar
Buy a 4.0 engine from one of the breakers on here, or Will TIllerey, or Doc Heydary on Facebook. Swap the 4.6 internals over or just put it in and run it, almost imperceptible power difference.
C3racer2000
Jun 28, 2013 10:39 PM
wreckdiver1321
Apr 6, 2013 12:49 AM
bumpus
Mar 13, 2012 03:20 PM
cleopard
Oct 20, 2009 08:50 AM
Tastang
Nov 30, 2007 05:47 PM
