D2 left for dead this morning... fuel pump? bad gas?
X2 on what dgi 07 asked. Do you have fuel pressure?
When you turn the key on, can you hear the pump run for a second? If not, you should check for power and ground at the pump connector. If you can hear it running, then I would check the fuel pressure at the schrader valve. If you don't have a pressure gauge, you can just depress the valve and see if fuel sprays out of it. If there is pressure in there it should spray out, not just dribble out.
Good luck.
Good luck.
It Might be a long shot, but I had a very similar problem with my '01 Mustang a few months back. The fuel pump died and did exactly what you're talking about. We later found out that when the fuel pump died, it sent electrical feedback back to the ECU and fried it too. Just a guess, I don't know if there are systems in place on a Disco to prevent that from happening.
LOL! They are nice enough to give you a schrader valve to check fuel pressure, but not nice enough to make it easy to get to.
The OP clearly knows how to keep his Disco going with 190k on the clock and recent work done, and being aware of that I don't mean any offense by suggesting something so simple: press the inertial switch on the passenger side firewall. It also interrupts the fuel supply, but it should flash your hazards, too.
For what it is worth, family members of mine (not me!) have run my Disco dry of fuel and cranked it until the battery died, and I just recently replaced my 15 year old fuel pump for unrelated reasons (developed a leak that JB Weld couldn't fix).
Also, as the OP surely knows, the Crank Position Sensor has to have the washers in the right position or it won't work, and that solves a lot of fuel delivery problems on the forum. But since the original CPS was fine, that shouldn't be the issue.
![Smile](https://landroverforums.com/forum/images/smilies/H5uKDcM.png)
I have checked the inertia switch. It meters out good and changes state when tripped / reset.
I don't have a fuel pressure gauge, but while pressing the schraeder valve, no fuel comes out of the pipe. I have not tried this while cranking. The pump doesn't prime with the key. The fuel pump relay doesn't get picked. I have to jump out the relay and send power to the pump manually to get the pump to run,so I'm thinking either the CPS I put in was bad or the ECM isn't sending an output to the fuel pump relay.
... HER Disco going... ![Smile](https://landroverforums.com/forum/images/smilies/H5uKDcM.png)
I'd say you are on the right track. If the fuel pump has been replaced recently was that done by cutting the carpet or doing the whole pull of the carpet routine? Hoping for the latter.
Really the ecu, CPS and inertial switch are your suspects. I'd check that CPS again. Also you might want to blow out the connector with some electronics cleaner (spray can).
Sorry ma'am!!! Hahaha. My bad. I am old and therefore make assumptions.
A reading for fuel pressure would be ideal, but we work with what we have.
If I'm reading this correctly, you get the pump to run when you jumper it. I can only assume you are using the terminals at the relay box. Try swapping the relays and see if you are getting power. Relays do fail often enough. If not. The next step past the relay would be ECU, if I'm not mistaken.
Before you do, swap out the relay.
