D2 lift kit?????
Old Aug 4, 2012 | 01:22 PM
  #21
coors's Avatar
Originally Posted by MuleyJ
I happened to be browsing the Terafirma sight and noticed that the meduim duty coils for the rear(the ones included in the most of the kits that are sold) have this discription:
Has anyone used the medium rears and achieved the correct amount of lift, or are some of you guys combining the HD rear springs with the medium fronts?
Wait... I purchased and am waiting to install a MD Terrafirma kit(front and rear). Should I be concerned that my ride will not be level? I have the ARB winch/bull bar installed. Will I have rake without 1" rear spacers?
Old Aug 4, 2012 | 03:36 PM
  #22
coors's Avatar
Should have mentioned I have NO winch on the bumper.
Old Aug 5, 2012 | 07:10 AM
  #23
ebg18t's Avatar
The TF HD 3" kit is actually very comfortable.
Old Aug 5, 2012 | 09:49 AM
  #24
ZGPhoto's Avatar
You'll be fine. I've seen a heavy duty custom bumper on stock springs and there wasn't really a rake. The 2" MD springs will be good.
Old Aug 6, 2012 | 09:12 AM
  #25
ZGPhoto's Avatar
Installed the new kit on Friday, couldn't be happier with the results! Several shock bushings on the OME kit I had on were blown. And the new ride quality and height blows the OMEs away.
Old Aug 6, 2012 | 10:45 PM
  #26
BrandonS's Avatar
Oops, missed that one. So it was 3" around with 2" HD front and 2" MD+spacer in the rear?
Yes this is correct. I made the measurement from the roof rack rail to my garage door frame before and after so it's a median of the front/back. The spacer was 1" Do note that I used the standard length shocks as well. I was told you don't want to use the longer ones unless you get extended brake lines.
Here's the only profile picture I can find at the moment. It has a slight rake so you could forgo the spacer if you wanted.
Old Aug 8, 2012 | 09:19 AM
  #27
MuleyJ's Avatar
Thanks for the pics and it is good to hear that everyone is liking their terrafirma kits. I ordered the TF springs and dampner from lucky8, but I found a set of OME shocks on CL that look good for very reasonable money, we will see. Thanks for the help!
Old Aug 8, 2012 | 03:48 PM
  #28
ebg18t's Avatar
Here is a pic of a 4.5" RTE lift On 33" tires for comparison.
caymandrew
May 9, 2015 10:05 PM
Bostonc16
Mar 7, 2015 10:32 AM
caspian
Feb 19, 2011 06:41 PM
majrmike
Oct 9, 2007 03:13 PM
studlee
Aug 8, 2006 10:29 PM
