D2 ran out of gas. Can't keep running. Please help
So my 1999 D2 ran out of fuel (v8 has engine) I put 5 gallons in it but it would keep shutting off after a few minutes running. Then I would have to put start fluid in it to get it to crank. After sitting for a while it will crank up no issue but only run about 10 minutes and shut off again. I replaced the fuel pump with a new one and still getting the same results. What else could be causing this issue? Please help?
