D2 stalling when stopped, won't start
Old 08-23-2015 | 07:31 PM
DiscoIIBeach's Avatar
4th Gear
Default D2 stalling when stopped, won't start
I have 2003 disco 2. Engine runs great but it will sometimes stall and won't start, only after coming to a stop, never when rpm's are up. At times it will start again just fine. The times it won't, the engine cranks fine but it just will not turn over. I suspect either the crank position sensor or the fuel pump relay. Could it be anything else? This problem makes my D2 unsafe to drive and I would appreciate anyone's help who's had a similar problem or anyone who may know the most likely cause or any other potential causes. Thank you very much for your help.
Old 08-23-2015 | 09:27 PM
Bom2oo2's Avatar
Start with simple things,
Clean inside trottle body ,
Cleat MAF sensor with cleaner, (you can buy from auto part stores)
Make sure sensor plug is connected securely ,
Then if still same you can check other possibilities , like crank sensor , etc
If you have a OBDII reader will be a lot of help for you,
Old 08-23-2015 | 09:33 PM
coors's Avatar
The fuel pump relay is very easy to rule out with this two second trick. Simply, switch relays with a known working one. Swap the relay in front of the fuel pump relay and go for a drive.
Old 08-23-2015 | 11:45 PM
4th Gear
thank you "Bom2oo2" & "coors". already cleaned relatively new maf sensor with maf sensor cleaner and throttle body with throttle body cleaner yesterday but it didn't help solve the problem. Also tried switching relays at a time when car wouldn't start, but that didn't get it started either. All were good suggestions that I've already tried. I do not have OBII scanner. Do I need to get one? It would probably be cheaper than getting my car towed to the mechanic and paying an additional $50 to get it scanned.
Other than the Crank Position Sensor, what else could it be? Much thanks again.
Old 08-23-2015 | 11:50 PM
Joemamma1954's Avatar
My pocket money is on the Crank sensor, but then again. I have a Disco 2, so I don't have any pocket money.
Old 08-24-2015 | 08:54 AM
Bom2oo2's Avatar
Yes , it's best to invest in a good scanner since you own a D2,
You will use it a lot, & it will save you money in long run,
There is planty of choices, I like my (icarsoft i930). It's made for Landrover / jaguar , & also works on all other cars , it does a lot for for the price, $130-150,
& you don't have to guess what's wrong anymore , it tells you,
Timebus
02-17-2011 10:10 AM
zopa
11-27-2010 03:26 AM
welderjon
11-01-2009 11:53 AM
poormane
01-21-2009 04:13 PM
Quick Reply: D2 stalling when stopped, won't start
