Damaged Bolt Holes on Head
Old Mar 23, 2018 | 11:06 AM
lrnoob's Avatar
Default Damaged Bolt Holes on Head
I have 4 or 5 damaged bolt holes on my heads where the intake manifold bolts are to go. They aren't damaged all the way down, just the first few threads.
What is the best repair for this?
Old Mar 23, 2018 | 12:12 PM
Jeff Blake's Avatar
Something like this: Sears.com
You want to use rethreaders, not taps.
Old Mar 23, 2018 | 12:25 PM
Alex_M's Avatar
Also found under the name thread chase.
Old Mar 24, 2018 | 12:13 PM
OffroadFrance's Avatar
There are a couple of options, insert thread inserts in which case you'll need to drill them and tap them or fit larger studs and drill out the manifold holes. There are kits around to do this. On the TD5 it's commonplace for the exhaust manifold to warp and damage/snap the studs and it only leaves these two options also.
http://gigglepin4x4.net/hd-td5-exhau...kit-1564-p.asp
There are many kits around much cheaper than this one.
Old Mar 24, 2018 | 07:12 PM
Jwehking's Avatar
I had same on all 4 corners. Helicoils and good to go. Didn’t even take me 30 minutes. Bought online for less than $20. I didn’t realize until I already had the heads on the block but I was still ok. Just vacuumed out the shavings afterward.
lrnoob
Mar 29, 2018 05:37 AM
Jst4fun
Oct 16, 2017 09:51 PM
knightmetro
Nov 12, 2014 11:42 AM
focusontheworld
Oct 21, 2012 01:00 AM
jcostello
Nov 2, 2006 10:28 PM
