Damaged Diff Stick
Old Dec 10, 2006 | 05:26 PM
toms_disco's Avatar
4th Gear
Default Damaged Diff Stick
A very very big man decided to force my stuck Diff Selector Stick (inside the Cab) to move when it was well and trully jammed.
He got it to move out of HIGH DIFF, only problem is that now I cannot engage LOW DIFF (locking diff stills works in HIGH ONLY).
I've re-aligned the multi-spline cog which is connected to the Diff Stick linkage between the diff gear box and the selector stick but this means I can only engage Low or High???
I am presuming the linkage has been bent? It looks easily possible as it is a weedy little piece of metal.
Is it possible to bend it back, move the pivot point??? Basically if anyone has any thoughts that will give me guidance I'll be very grateful.
Cheers
Tom
Old Dec 10, 2006 | 07:29 PM
Default RE: Damaged Diff Stick
The linkage is pretty weak and should probably be replaced cause I think it will be even weaker if you try and straighten the old bent one.
Mike
maduwage
Sep 3, 2007 08:15 AM
jwmstang
Apr 16, 2007 01:47 PM
hanyshamloul
Dec 20, 2006 07:43 PM
Justin
Jan 10, 2006 01:12 AM
kennims
Apr 18, 2005 10:35 PM
