DAMS - Discovery Acronym Management System
Our forum language is changing with the time. In the future, we may not use any words in a post, as it can be written with all acronyms.
Example: 03 D2 HSE 71k w/ ABS-TC- HDC 3 Amigo’s SOS
For standard web acronyms see the “Internet Acronym Dictionary”
http://www.gaarde.org/acronyms/?lookup=A
The following is an acronym list to share with others who are learning that to “walk the walk” of the Discovery, and they also need to “talk the talk” of the Forum. We are making up new acronyms all the time, so be prepared to keep adding to the list.
Note: please let me know of any errors or omissions
A
ABS - Anti-lock Braking System
ACE - Active Cornering Enhancement (D2)
A/C - Air Conditioning
AEL - Advanced Evaporative Loss System
AIC - Additional injector controller
Amigo - 3 Amigo’s warning lights ABS-TC-HDC (D2)
ARB - Manufacturers of 4x4 accessories
AT - Automatic Transmission
AWD - All wheel Drive
B
B4 - Before
C
CDL - Center Differential Lock (D1 94-98, and D2 04)
CO - Carbon Monoxide (smog test)
D
D1 - Discovery I (US 1994-1999) (1989-1999)
D2 - Discovery II (1999.5-2004)
Diff - Differential
E
EBD - (D2) Electronic Brake force Distribution
ECU - Engine Control Unit, Gems (D1) 96-99, Bosh (D2) 99.5-04
EGR - Exhaust Gas Recirculation (not used on the Discovery)
F
FAQ - Frequently Asked Question
G
GEMS - Engine Control Unit, General Engine Management System (D1 96-99)
H
HC - Hydro carbon (smog test)
HDC - Hill Decent Control (D2)
HG - Head Gasket
HID - High intensity discharge (xenon) lights
HSE - Discovery model (D2) 03, 04
I
IAC - Idle Air Control sensor
IM - Intake Manifold
IMO - In my opinion
J
JK - Just Kidding
K
K&N - Brand of air filter
L
LR - Land Rover
LSE - Discovery model
LOL - Laugh out loud
M
MAF - Mass Air Filter sensor
mm - millimeters
MPG - Miles per gallon
MPH - Miles per hour
M&S - Manual and Sport Mode – automatic transmission
MTBF - Mean time between failures (reliability)
N
NG - No Good
O
o2 - Oxygen as oxygen sensor
OBD-II - On Board Diagnostic (engine fault codes)
OEM - Original Equipment Manufacturer
OME - Brand 4x4 accessories – Old Man Emu
P
PAS - Power Steering Pump
PM - Personal Message
PO - Previous Owner
Q
QED - Quite Easily Done
R
RR - Range Rover
RRC - Range Rover Classic (1970-1996)
Rave CD - shop manual download http://www.landroverresource.com/
S
SAI - Secondary air injection (D2) 02, 03, 04
SES - Service Engine Soon warning light
SD - Discovery model
SE7 - Seven passenger SE
SLS - Self Leveling Suspension (D2)
SVS - Shuttle Valve Switch ABS-TC-HDC
T
T-case - Transfer Case
TC - Traction Control
TPS - Throttle Position Sensor
U
U - You
UR - You’re
V
VC - Valve Cover
VSS - Vehicle Speed Sensor
W
WD40 - Brand Name penetrating oil
X
X fer - transfer case
XYZ - Switch on side of automatic transmission to tell the controller the selected gear
Y
Y - Why
Z
zzz - that’s it for tonight
A
B
B4 - Before
C
D
Diff - Differential
E
F
G
H
HG - Head Gasket
I
IMO - In my opinion
J
JK - Just Kidding
K
L
LR - Land Rover
M
mm - millimeters
N
NG - No Good
O
P
PO - Previous Owner
Q
R
RR - Range Rover
S
T
U
U - You
UR - You’re
V
VC - Valve Cover
W
X
Y
Y - Why
Z
Wrong, HSE is a model designation on all land rovers including freelander, RRS, RR, Discovery models.
There are base models now with different models. For example Discovery 4 has XG, XS, HSE
Freelander two has S, XG, XS, HSE
Range Rover Sport has SE, HSE, SC also HSE with LUX package
Range Rover, Vogue, Vogue SE, SC, Autobiography editions. depending on country some are a package and some are more personal.
And don;t forget all the special Editions
XD RR,D1
Camel Trophy defender, freelander, DI, RRC
Rhino RR P38
Holland and Holland RR P38 AND new RR 2010 Holland and Holland edition
Linley RR p38
Safari D2
kalahari Defender South Africa
West Minister RR and D2
Versius Orange RRS 06
G4 defenders, Freelanders, Freelander2, D2,D3, RR, RRS
Autobiography Range Rovers and Sports
Fire and Ice Defenders
Trek vehicles since 1997
and most of your acronyms for systems and module names arent even close with what we use.
XD RR,D1
Rhino RR P38
Linley RR p38
Safari D2
Rovin, good job, sometimes we forget that what we're saying doesnt even make sense to everyone. I said CDL to a mechanic once and he didn't have a clue i was talking about center diff lock...
Imagine a 2010 RR HSE with all the bells and whistles and all of those bells and whistles have at least two or three modules with their own acronyms.
I have a list of my training manuals that list something along the lines of fifty acronyms for modules. Thats not including the regular Periodic tables listed including NOX, CO, MO, CH,
Oh and we have wiring color schemes which differ per vehicle. Older ones use a different system then the newer ones.
There is alot there trust me.
I think it was more of a informative thing rather than a technical thing. But i'll let eaglewing answer that.
This is the Land Rover Discovery Forum for Discovery I and Discovery II owners and comments and lists should be focused for those people who want to know about their Discovery trucks (Not LR3 or RR or Defender). This is why I made the list of Discovery items that kept coming up in our forum. Newby’s questions of what is this were sometimes not answered. In the spirit of openness I felt this small but focused list was important to the understanding of our conversations in this forum. I am not a trained Land Rover mechanic and I am always humbled by the knowledge that others have. What makes this form great are the people and their sharing of knowledge. We solve problems together.
ha to most CDL is commercial drivers license! I am sure we have quite a few others that are rover specific that would mean something else to other people. I thought it was a great post. I also remember a time when I had to ask what TPS meant, so maybe it will be beneficial to someone.
Thank you guys for the kind words, I feel better about this now.
I have a 98 DI which is electronic simple compared to the DII’s with many more acronyms.
This list started so that I could understand what was being talked about on the forum for both DI and DII’s. It was a good learning exercise.
If it worked for me so I decided to share it with the forum.
