that dang ACE light...
Old Jan 3, 2008 | 12:14 PM
johnnybob06's Avatar
Default that dang ACE light...
... First off, I hope everyone has had an amazing New Year, so far!! :] I feel that 2008 is gunna be a great year!
Anyway, ever since I've had my truck, the ACE light always seems to haunt me!
I've recently changed out the ACE/PS fluids with Valvoline Synthetic + Lucas, and I thought that had worked, but alas, it still turns on randomly after I drive over very bumpy "being renovated" highways.
Does the ACE have a filter?
Thanks so much!!!
Happy New Year!
John-Robert
Old Jan 3, 2008 | 12:22 PM
Default RE: that dang ACE light...
Yes the ACE has a filter but I would bet you have a short. That light is ment to come on when the system over heats and if you have good circulation in the reservor then it is not mechanical.
Old Jan 3, 2008 | 12:38 PM
Ok, well, I don't believe the filter has ever been changed. Atleast not in the 25,000 miles since I've owned it.
Is it something that I can get at the store and replace easily?
If it is a short, what do I need to do?
Thank you so much Mike for your help!!
I can't express how much appreciation I have for you. :]
John-Robert
Old Jan 3, 2008 | 02:11 PM
A filter, as I have already mentioned, is not what is needed, go read my post again. As for replacing the filter, it is about a $65 filter a little larger the the size of the first joint on your little finger and I would, if it were needed, rather not see you try to replace it.
Go have some track down the electrical issue.
Old Jan 3, 2008 | 04:24 PM
OK, that's fine. When is that filter supposed to be changed out then? How many miles? I'm right at 53,000
I'll go and have someone track down the electrical problem then. Thank you.
Frank4
Apr 22, 2014 07:37 PM
Tin_Man
Apr 12, 2014 11:12 AM
ljdiscovery
Jan 14, 2014 11:08 PM
bamaboy473
Jun 3, 2012 08:08 PM
ljdiscovery
Jul 31, 2009 03:14 PM
