Dash curling up near windshield
Old Mar 3, 2008 | 09:31 AM
PITTDISCO's Avatar
Default Dash curling up near windshield
Anyone know of a fix for this?
Old Mar 3, 2008 | 10:05 AM
Default RE: Dash curling up near windshield
I have seen some take a hair dryer to it , heating and bending the dash back, but bottom line, a lot of them did this as they got older and I don't think you can stop it.
Old Mar 3, 2008 | 10:15 AM
Mark G's Avatar
How about a 3" drywall screw? There's got to be something pseudo-solid back there to screw into to hold that corner down ....like a 2" bundle of wires
Seriously though, if the vinyl is delaminating from a rigid dash base you may be able to get in there, clean thoroughly,and re-adhere with an industrial-type adhesive (PL-500). If there isn't a rigid base under the vinyl, the right way would be to remove the dash and put some sort of rigid material beneath it (sheet steel) and fasten down the vinyl with an adhesive or some type of fasteners (screws maybe?). Put a heat lamp on it to make it more pliable so it won't crack when you're working on it. Be careful as you handle the dashtoo. These old vinyl dashes get brittle as pie crust in their old age! Removing the dash would be a lot of work.
Old Mar 3, 2008 | 10:25 AM
PITTDISCO's Avatar
I was thinking of cleaning with rubbing alcohol and using contact cement or Liquid Nails, on a hot day, 80-90+.
Old Mar 3, 2008 | 12:30 PM
JEFIII's Avatar
I believe John Craddock's in the UK sells a finisher kit that will repair and cure the curling problem forever. Give 'em a call. JF
Old Mar 3, 2008 | 01:49 PM
okdiscoguy's Avatar
go to http://roverconnection.com/click on the Discovery tab and look about halfway down in the list. There is a dash repair kit for about $60. Just what you should need.
Old Mar 3, 2008 | 04:34 PM
Landzu's Avatar
ORIGINAL: okdiscoguy
I have this on mine and it works.
Its hard to get to all the screws but I had my windshield replaced just after wards.
Old Mar 3, 2008 | 09:52 PM
mordor110's Avatar
I found one of these on a Disco in the junkyard and got it for $5. I haven't got around to putting it on yet. Partly because I wasn't sure how I was going to get the curl flat enough for me to get the screws started. The hair dryer idea might be the solution. My dash looks like a potato chip! The trim kit looked pretty good on the Disco I took it off of, also looked like it was factory.
Old Mar 4, 2008 | 07:23 AM
Landzu's Avatar
[quote]ORIGINAL: mordor110
You line it up and push it down and start the self tapping screws.
Before I had my window replaced I heated a wire and used
it to melt a small hole to start the screws, this was after
it was held down by by screws in the easy spots to get to.
matt3502
Apr 28, 2020 02:55 PM
ljdiscovery
Dec 20, 2013 03:09 PM
DISCO1995
Dec 5, 2011 09:44 PM
Queenie
Jul 1, 2011 01:11 PM
faversham
Nov 12, 2009 01:26 PM
