Dash shows Drive - Shifter Park and wont start
Old Feb 22, 2009 | 05:41 PM
tiredone's Avatar
Default Dash shows Drive - Shifter Park and wont start
Have 99 LR DII that will not start. I could not get the key out initially, but after reading some threads disconnected a solenoid and key came out, but car still does not start. All the dash lights work. The dash indicates "D", shifter is all the way forward for park, but shifter light designation shows D. What is the probelem?
Old Feb 22, 2009 | 06:11 PM
The truck thinks that it is in drive.
Either your shift linkage is broken or you have somthing else going on.
Can you move the shifter with the key out of the ignition?
Old Feb 22, 2009 | 06:25 PM
tiredone's Avatar
Shifter is locked in park position and cannot move it with or without the key in the ignition
Old Feb 22, 2009 | 06:31 PM
tiredone's Avatar
Additionally, I can move the car by pushing it even when the shifter is in the forward park position. That would seem to be broken linkage right?
Old Feb 22, 2009 | 06:37 PM
Yes, broken linkage, the transmission is in drive and the shifter is in park.
Set the parking brake and choke the wheels, you will need to have a shop take care of this for you.
I have not the slightest clue as how to replace the linkage.
I bet if you put the key in the ignition and turned it to "run" and put your foot on the brake pedal you could then shift out of park.
Old Feb 22, 2009 | 11:21 PM
tiredone's Avatar
I have read in other forums that it could be something associated with the brakes, like a fuse or something. Before this happened, I could feel a "click" on the shifter when the brake was depressed and it disengaged the locking on the shirfter allowing to shift. I do not feel that "click" anymore. If it is the shift linkage though, where would it be, a broken cable hanging from under the car or something?
Old Feb 23, 2009 | 12:12 AM
AK Rover's Avatar
The D2 uses a cable that runs from the shifter to the driver side of the transmission to shift the transmission. I think it is held in place with clips so even if it is broken it won't hang down below the vehicle but will be quite obvios if you climb under the truck.
Looking at the RAVE manual, replacing the shifter cable doesn't appear to be very difficult but definitely time consuming. Unless you are rather mechanically inclined and have some free time on your hands I would consider having a mechanic replace the cable if that is the problem.
disconic
Jun 4, 2016 02:57 AM
disconic
Dec 28, 2014 06:25 PM
wabuson
Nov 21, 2013 06:25 PM
V.haggard
Jan 31, 2012 01:44 PM
gustav23
Dec 15, 2011 01:12 PM
