Dashboard Curling repair kit
Old Sep 2, 2014 | 05:51 PM
OffroadFrance's Avatar
Excellent write up earlyover and also some good tips and observations from all. It seems so silly but I've never checked mine and wouldn't know whether it's got the 'bends' Tomorrow I have a look and check it out.
Old Sep 3, 2014 | 12:24 PM
earlyrover's Avatar
This is just a brief note to let everyone reading this thread know that my curling dash "fix," as described in detail below, is still in place, and hasn't changed in the slightest.
After two summers of a lot of heat, with sun beating on dash, and two winters of cold, dash remains as if it was never curled at all ever; looks new as can be, level all the way across, no lifting anywhere; since repair, heat/cold has not affected it in the least Once again, the epoxy I used has not yet failed me on this or on the numerous other things I have used that epoxy on------for name and description of this awesome epoxy, along with details about how I did my repair, see my description below. I think my repair was way better than what is suggested in using the so-called "kits," because my repair is done with no screws, no metal straps, nothing ugly or different from the way the dash originally looked when brand new.
Old Sep 4, 2014 | 09:31 AM
matt3502's Avatar
Default Das repair kit costs
I got the quote back from Devon 4x4 in the UK. The Kit itself is $52.50 and the shipping to the US (Fairfield County, CT) is $ 86.18. Not cheap, but now we know there is a kit. Picture from the Devon 4x4 site:
http://www.devon4x4.com/components/c...bfe60955bd.jpg
Old Apr 25, 2020 | 03:40 PM
cvhyatt's Avatar
Anyone else try/have luck with a glue only repair?
Old Apr 26, 2020 | 04:17 PM
Extinct's Avatar
I was thinking about this the other day as one of mine is doing it. Was thinking about heating it up pretty hot with a heat gun, then holding it down in place while quenching with water to freeze the molecules in the new position. That method works when forming other plastics, not sure it would work on the dash. If you try it, let us know if it works.
Old Apr 26, 2020 | 04:33 PM
cvhyatt's Avatar
Good idea @Extinct . I need to find the right epoxy. Was thinking about smearing the epoxy in a location while it is sitting in the hot florida sun, then putting a 1x2 across the section, then putting a bottle jack on top of it, extending it to the top of the windshield and another board between the jack and the windshield frame. I think I will prototype this without the glue to see if it provides enough pressure to flatten it out. Will post some pics when I get this tested out.
Old Apr 26, 2020 | 04:38 PM
Extinct's Avatar
My thought was more about not using epoxy, just warm the plastic enought to make it soft, then freeze it in position with water.
Old Apr 26, 2020 | 04:42 PM
cvhyatt's Avatar
Oh wow - i wonder if that would work? I really like the idea of zero glues and screws. I'll give that a shot first.
Old Apr 27, 2020 | 10:06 AM
Richard Gallant's Avatar
Add pictures if you go for it mine is pretty "curled", but I do have a hot air gun to warm things up
Old Apr 27, 2020 | 01:40 PM
losinov's Avatar
I made a short DIY on the kit here: https://landroverforums.com/forum/di...air-kit-96538/
