Dashboard Illumination Problem
Old Dec 18, 2025 | 11:27 AM
hse72004's Avatar
3rd Gear
Hi, message from 15 years later. Just wondeing if you solved the problem after all? I am having the same issue with my 04 hse. Checked all the fuses and connectors but no luck. Thanks in advance
Old Dec 18, 2025 | 06:26 PM
Extinct's Avatar
Have you looked at the Rave yet?
Old Dec 19, 2025 | 08:44 PM
hse72004's Avatar
3rd Gear
I did. Turns to be the #3 fuse was burnt. But as long I put it a new one, it will be burnt shortly.
Old Dec 20, 2025 | 12:04 PM
redrover75's Avatar
Mine was the dimmer switch was bad. might be worth throwing the part at it.
Old Dec 20, 2025 | 12:12 PM
hse72004's Avatar
3rd Gear
Thanks for the hint! I was looking on Atlantic British but their dimmer switch is getting me confused. We’re talking about the rheostat **** switch right?
Old Dec 21, 2025 | 09:14 AM
mollusc's Avatar
That is the wrong switch -- it's a floor-mounted high-low headlight beam switch. Note that it doesn't say it's for a Discovery. The D2 dashboard dimmer is a roller switch.
Old Dec 21, 2025 | 01:28 PM
Harvlr's Avatar
Mollusk is correct. The switch you're showing is for a Series Land Rover, for dipping the headlights. Not for your vehicle at all.
bowser881
Apr 15, 2025 11:42 AM
honda50r
Jul 11, 2011 06:40 PM
joefresso
Feb 24, 2011 02:40 PM
tlblues
Sep 2, 2010 04:42 PM
