Dashboard warning lights
Old Feb 18, 2008 | 10:54 AM
dgm's Avatar
dgm
Default Dashboard warning lights
I have a 03 disco with 55k.At first the ABS, brake and traction control lights would come on when it got cold, or if I braked before a speed bump, but then go off afterI restarted the engine. Now all of the lightsplus the hill descent light stay on. I'm thinking it's a sensor problem. We've had the modulator replaced under warranty about a year ago. Any thoughts??? I don't want to have to take out a second morgage to get this thing fixed/looked at at the dealership. It seems they are the only ones with the "factory diagnostic equipment" to determine what the problem is.
Old Feb 18, 2008 | 10:58 AM
DuplinDisco's Avatar
Default RE: Dashboard warning lights
Sounds like the famous "Three Amigos". I'm sure on of the D2 guys can help you on here.
Old Feb 18, 2008 | 11:40 AM
You need to find a mechanic that has a lap top type scanner that can read the brake faults and then have them cleared, usually they won't come back.
If your last repair was under a year ago, go back to the dealer cause you have a 1 year warranty, if over a year don't go to the dealer cause they won't clear the codes for you, just sell you more parts.
Old Feb 18, 2008 | 01:12 PM
dgm's Avatar
dgm
I just checked my brake fluid level and it's fine. I took it out on a gravel road near by and there is no ABS.
Old Feb 18, 2008 | 01:22 PM
Are you still in warranty? Chances are your ABS unit has failed again.
Old Feb 18, 2008 | 01:42 PM
dgm's Avatar
dgm
It up 2/7/08
Old Feb 18, 2008 | 02:41 PM
Call me right away, I'll be here for 1 hour.
303-862-7680
Old Feb 18, 2008 | 06:05 PM
dgm's Avatar
dgm
Mike,
I left a msg at the number provided.
Old Feb 18, 2008 | 09:03 PM
dgm's Avatar
dgm
Mike,
I should have left my cell number on the message. It's (843)860-6840.
cipher982
Nov 9, 2019 11:22 AM
Tropical Disco
Jul 1, 2008 03:24 AM
Chrisinhouston
Mar 2, 2008 05:21 PM
Discoverydiesel2003
Nov 13, 2007 07:09 AM
jonnymcd
Jul 25, 2007 03:11 AM
