Dead instrument cluster:
Old Oct 17, 2013 | 08:01 AM
G Reeves's Avatar
Default Dead instrument cluster:
ok, this has me a wee bit stumped
2003 Disco with 120k miles
Came out to it this morning and no instrument cluster working. The onlt light that works is the SRS light and that goes out after it starts.
ALL other electrics are working. The Disco starts and runs fine but the instrument cluster is DEAD, nada, nothing, no warning lights, temp, tach, speed or fuel gauge. EVERYTHING else works fine and perfect...
The Ultra gauge works fine and the only code it has thrown is 0462 fuel pump????
Any helps or hints would be greatly appreciated. Thanks
Old Oct 17, 2013 | 10:37 AM
bballjames's Avatar
I've had this same issue before. It only happens in the winter time when it's pretty cold out (like below freezing). Truck runs great, no codes, just no instrument cluster. After the truck warms up after 10-15 minutes of driving, all of the sudden everything will turn on. Does your cluster turn on after it warms at all? Or is it just dead?
My rover mechanic mentioned it was probably due to a bad fuse box, the one inside the truck. But then it warmed up and was summer time, and it stopped doing it, so I didn't worry about it. Now that winters back though, it might be happening again.
Old Oct 17, 2013 | 12:23 PM
G Reeves's Avatar
No does not turn on, stays dead....
riko suave
Mar 18, 2009 04:34 PM
Panic
Feb 23, 2009 01:41 PM
CandiMan
Oct 30, 2008 01:39 AM
coldfrez
Oct 1, 2007 09:49 AM
Greg
Aug 8, 2007 04:47 AM
