Dealership only place to get the radio code?
Old Feb 21, 2016 | 01:47 AM
DiscoCam's Avatar
They are to unlock the radio after the battery has been disconnected.
Check your dealer service records. Mine is listed on them.
Old Feb 21, 2016 | 02:06 AM
LR03NJ's Avatar
Originally Posted by SALTYRoverSE
I'm sorry for my ignorance, but what codes are you talking about??? I've never heard of this.
The standard radio for the SE dont need a code. The radio with navigation needs a 4 digit code to unlock each time you disconnect the battery.
Old Feb 21, 2016 | 05:30 AM
mln01's Avatar
I have the radio code for my truck but I've never needed it, even when the battery has been disconnected for an extended period.
Old Feb 21, 2016 | 09:54 AM
number9's Avatar
Same as I found. Battery disconnect only required changing AC controller back to F.
Radio R&R supposedly requires code. Suspect when connector taken removed continuity will be lost between pins keeping memory active.
Good idea to get your radio/key codes from a dealer just to have on hand for when the SHTF. Need to do that myself, understand some may provide at no charge and might even do over phone/email if proper documentation sent. Do we have any dealer/members here who will provide that service for free or minimal cost?
Old Feb 21, 2016 | 11:48 AM
jamieb's Avatar
Originally Posted by number9
Same as I found. Battery disconnect only required changing AC controller back to F..
I didn't know we could switch to F. Figured it was British and celsius only. :-)
Old Feb 21, 2016 | 12:26 PM
number9's Avatar
Owner's manual info.
Old Feb 22, 2016 | 05:48 AM
mln01's Avatar
Hold down the Recirc button (three arrows forming a circle, far right) and then the climate control power button immediately thereafter. The LCD display will show Fahrenheit and Celsius indicators, and then after a couple of more seconds it will show that the change has been completed. Voila!
Matty J
May 14, 2011 01:26 PM
noahsfortune
Jun 20, 2010 03:59 PM
Fing Fang Foom
May 5, 2010 09:14 PM
