Death to another MAF
Old Jun 20, 2022 | 06:12 PM
Thealooox's Avatar
4wd High
Default Death to another MAF
I am now on my second replacement MAF for my 2000 D2 V8
The previous MAF died when off roading, I only noticed once the vehicle smelt very very rich, and putting a scanner on it I got the P0102 code
After reading the forums I decided on ordering a new MAF, I have been running with the new MAF (Bosch) for about a month now, but today my vehicle popped a new code on my ultragauge, P0102 is back, and smelling very rich.
I checked the connections and I’m sure it’s not a wiring issue, I made sure to clean the wire terminals with contact cleaner just in case.
I have never cleaned this new MAF as I have read that’s what can kill them.
I tested the old MAF and it did not work either, both MAF’s IAT sensors work, but they both do not report back the g/s result to my scanner.
I can’t keep spending $500 a pop on a new maf, so something else must be going on. I also think the last round of driving with bad maf has killed my O2 sensors.
Any advice would be awesome. Just want to trust my D2 again.
EDIT: Moved this to the D2 Category
Old Jun 20, 2022 | 07:37 PM
RA122125's Avatar
Banned
I just replaced mine with one of these, did it pretty recently so I haven't had it for very long, but it's working fine so far. Just swap the MAF into your original housing, easy enough to do if you have the tools.
Amazon Amazon
Also, just because a MAF code comes up, that doesn't always mean it's bad. It could also mean you have a vacuum leak somewhere. May be worth some time to diagnose to be sure. Just a thought
Old Jun 20, 2022 | 08:19 PM
Best4x4's Avatar
It's always a good idea to clear the adaptions whenever you do a tune up or replace an MAF, O2 Sensor, IAC, or TPS sensor.
Old Jun 21, 2022 | 07:13 AM
brivalen's Avatar
Clear how?
Old Jun 21, 2022 | 09:02 AM
Best4x4's Avatar
Hawkeye, Nanocom, T4, or any higher end scantool
Old Jun 21, 2022 | 09:13 AM
brivalen's Avatar
Interesting. What's clearing it do?
Old Jun 21, 2022 | 10:31 AM
RA122125's Avatar
Banned
For those who don't have a scan tool, Doesn't disconnecting the battery for a few minutes also clear the memory?
Old Jun 21, 2022 | 11:34 AM
Best4x4's Avatar
I've never seen the adaptive settings get defaulted via a battery disconnect. Same with SLABS faults = they do not clear or reset without a scan tool.
​​​​​​When the Adaptive settings are cleared it puts all config at a default baseline, then when the vehicle performs a drive cycle it "adapts" to the input the sensors are giving the ECU. If you slap on a new part it will run at whatever the adaptive settings are currently for it. Once cleared or reset the new sensor will send new data and that can be the difference in MPG, idle, and engine performance. Now after several drive cycles it "should" adapt to the new sensor, but sometimes to get a drive cycle to complete can be a bit of a PITA. That's why it's just easier to reset the adaptions.
Old Jun 21, 2022 | 12:02 PM
oaty's Avatar
Default 2000 DII on its 3rd MAF
I replaced the last two MAF about 2 years apart. The MAF were after market, so I am sure that was part of the problem. It took me awhile to diagnosis since my 2nd MAF was fairly recently installed.
Thealooox
Aug 23, 2022 05:34 PM
potxoli
Sep 5, 2013 09:18 PM
Switzer
Jul 9, 2011 07:02 AM
ezikial4
Jun 28, 2009 08:26 PM
jkid
May 16, 2008 08:55 PM
