Definitive answer on Key Fob Reprogramming
Old Aug 16, 2019 | 09:00 PM
  #71
Ben Matheson's Avatar
Originally Posted by xisled
I will also confirm my nanocom has reprogramed keys for me as well.
I had a key done with a nannocom and didn't need the bar code. Used the numbers printed on the circuit board
Old Aug 16, 2019 | 10:42 PM
  #72
joshjellel's Avatar
Originally Posted by Tomzsix
Disco Mike is correct. You need the bar code with new key fob. Period.
Clearly not true. I’ve got 2 used fobs from eBay that came with no bar codes unlocking my Disco 2, programmed by Trailhead 4x4 as I described above
Or are you just having a laugh at Disco Mike’s omniscience?
Old Aug 17, 2019 | 09:12 AM
  #73
Best4x4's Avatar
Disco Mike hasn't posted in years, and a lot of things have changed as far as what we can now access & do with our D2's. I remember WAY back when the D2's were just released if the ABS went nuts you'd better still be under warranty because no one could touch it without a T4. Let alone program keys, reset adaptive settings, or change BCU settings.
Now with the Nanocom for example all of those things are within reach.
Old Jan 11, 2020 | 11:18 AM
  #74
cvhyatt's Avatar
I'm at a loss. Its not clear to me what code I should be using to program the key fob. I am using the nanocom and have two new key fobs with bar codes. However the first digit of the first bar code starts with N. I am then trying to program in the six digits to the left of N. Did i do something wrong or get the wrong kind of key fob?
Old Jan 11, 2020 | 11:33 AM
  #75
cvhyatt's Avatar
I think I figured it out. I bought 433mhz key fobs.
Old Jan 11, 2020 | 12:22 PM
  #76
Sixpack577's Avatar
That sucks.
All U.S D2's use 315mhz
I hope you can return them
Old Jan 11, 2020 | 12:30 PM
  #77
cvhyatt's Avatar
Originally Posted by Sixpack577
That sucks.
Unlikely. I already have them cut. I just need to get a couple of used 315mhz but I only have the Nanocom for a week.
Old Jan 11, 2020 | 12:41 PM
  #78
Sixpack577's Avatar
Maybe you can work something out to extend the rental, considering the circumstances.
Old Jan 11, 2020 | 02:11 PM
  #79
Discorama's Avatar
Another option is to install a 433MHz receiver (cheap on ebay). 433MHz fobs are a lot cheaper. I haven't tried it, maybe someone has some comments on that?
Old Jan 13, 2020 | 01:17 AM
  #80
Rovertechwm's Avatar
Yes that would work. I have one that i can let you have for free. Only problem is that I am in Cape Town South Africa. If you can arrange for courier i can package for you.
Regards
Nicky
