Denver area drive shaft rebuild shops?
Old Nov 23, 2012 | 11:32 AM
CANAMDiscovery's Avatar
Default Denver area drive shaft rebuild shops?
I posted earlier this fall about the chirping coming from under the truck... It seems to have become worse.
Chirps badly with the first drive of the day...
As posted earlier, if I take the truck out of gear... To neutral the chirp slowly goes away as I coast down the street. Engine rev in neutral do nothing to effect the noise. I know it is nothing to do with the engine.
I have been noticing some vibration while at higher speeds.
Visually, the rubber boot at the forward end of the shaft is split and would require replacing. Greased regularly, even between oil changes!
I replaced the original shaft with a serviceable one about 50,000 miles ago.
My main question is this (as the post title suggests), where in Denver would you drop the shaft off for rebuild? I see several in my initial google search.
Would you even rebuild / balance this shaft or just buy a new one? How much should I be willing to pay for mine to be reconditioned? I know a new one will run me about $350.
Thanks.
Mike, I know you are in Denver Any suggestions?
Old Nov 23, 2012 | 11:39 AM
Externet's Avatar
Look/search for "driveline" on white + yellow pages.
Old Nov 23, 2012 | 11:44 AM
lr2001silver's Avatar
Banned
Hey Mike I have no clue what prices are there in Denver, but a new drive shaft from me will run you $300 delivered to your door step. I even include the 8 ny-lock nuts that you need to replace when changing the drive shaft. The chirp is a sure sign that it is going bad. The roto-flex on the rear diff will also cause vibration if its worn.
Old Nov 23, 2012 | 12:17 PM
The photo of the damaged rubber boot.
I also noted that this shaft did not have the zirc installed on the shaft itself. Just the ones on each of the U joints. 4 total. There is only an allen nut where I could add a zinc? or is the shaft already at the point of no return? Something tells me that adding to grease to an already chirping shaft is only looking for trouble in the near future.
Brett
lr2001silver, That was a call for DiscoMikes local opinion on a good shop..
I will consider your option... see what local rebuild deals are. thanks for your reply and opinions.
Brett
Old Nov 23, 2012 | 09:51 PM
Banzai Jimmy's Avatar
I've used both Englewood Driveshaft and Front Range Driveline - would recommend either shop. There's a shop that advertises on CL from time to time for a DII shaft for $350 (found one: *****Remanufactured Land Rover Discovery front shaft*****) - it's Colorado Drive Shaft. Haven't personally used them, so I can't recommend.
If that allen nut is in the female side of the spline/slip joint, then I'd say you could put a grease fitting there (some go with a needle style versus standard grease fitting to reduce the chances of it getting damaged).
Old Nov 24, 2012 | 01:29 AM
Thanks Jimmy,
It sounds like if I dont have mine rebuilt, LR2001silver is the best deal going, with a solid product. Hopefully make a decision over the weekend.
Old Nov 24, 2012 | 11:59 AM
Originally Posted by CANAMDiscovery
Thanks Jimmy,
Not a problem.
LR2001silver - Do you have some specs for your driveshaft? Parts mfgrs, joint size, etc.? Everyone raves about it, but I can't recall seeing any specs. FWIW, I'm just curious as I have no need for a DII driveshaft.
montez27
Dec 23, 2011 06:25 PM
bribake
Jun 2, 2009 11:44 AM
01 Discovery SD
Mar 1, 2009 12:11 AM
mc_eyes
Nov 8, 2007 10:48 PM
roverd
Jun 25, 2007 06:10 PM
