So a while I destroyed my CDL... transfer case works perfect unlocked but grinds when its lock
My question is can I save some time and just replace the front output section like you would do if you were installing CDL onto a 2002-2003? (circled in red)
Yes, you can remove the front output assembly, in situ. You will have to remove the frame mount bolts along with the bolts that secure the front assembly to the main assembly.
