Dexcool...Is corcorarun Dexcool?
I can attest to Disco Mike's statement - when I did my flush and swap this summer the plastic holding the o-ring for the cap was cracking off. I went a little extra and replaced most of the hose clamps too.
Hi, I'm new here so please excuse my inexperience to this sort of "thread".
I was researching the Dex-Cool coolant today (as I am looking at an '04 SE7 tonight!) just through GOOGLE and this older thread popped up. It is enough for me for me to decide even before I buy my Disco!!!
Copy and paste below:
https://landroverforums.com/forum/di...-repair-27657/
You can buy a vehicle with dexcool installed and remove it. If the radiator can't be flushed out (too much sludge) it is a $200 - $300 part. Keep that in mind when negotiating. The part you highlighted is like $25. There are ways to get most of the dexcool sludge out, if the vehicle has it.
On the down side, most Disco's don't need an excuse to overheat. So the Dexcool just takes that up another notch.
After doing what Disco said about flushing a couple of times with distilled water, do this. Put a 1/2 gallon of white vinegar in there and top it off with distilled water. Run it for about 10-15 minutes at idle with the heater on full blown. Drain it and watch the crap come on out. Vinegar works great in aluminum engines to remove calcium chlorides and aluminum oxides that these motors create, particularly if using that GM crap. Use the green stuff.
I will get flack for this, but trust me it works. Take an old piece of aluminum and dump some vinegar on it and see how well it cleans it up. And no, it will not harm gaskets/seals.
I purchased my Discovery used and until recently never thought about the orange Dexcool being a negative thing. Did Rovers come from the factory with Dexcool?
If so, could this not be a reawithout the issues with these trucks is the head gaskets going out early?
I have a leak...been told from the valley gasket at the rear of the motor. This may be a good time to do a flush. Disco Mike recommends Peak. I will see if I can find some.
Assume somewhere in the rave manual I can find how to flush the system.
Cheers, always good insight here!
In land Rovers infinite wisdom there is no drain plug on the radiator you must pull the bottom hose to drain the system. Drain it, fill with distilled water and run, repeat until everything comes out clear. There are commercial flushing agents you can buy, but unless you suspect that some has put a sealer in the system they are not necessary, I like the vinegar suggestion someone made earlier. I would replace the thermostat while you are there, it undoubtedly will get clogged with all the flushing.
here's where stat will clog, metering holes that bring hot coolant to trigger the remote stat. Also while flushing, reverse flush the heater hoses as well. Flow chart attached so you can check all the hoses, etc. Be careful of small plastic nipple fitting on radiator - they are very brittle.
