DI Brake Job
Old Oct 8, 2009 | 09:13 AM
jycsalas's Avatar
Default DI Brake Job
Ok I am going to be tackling my 1st DI brake rotor/pad job.... Do I just follow the rave manual or do you all have anything to add to the gospel??
Customer wants this kit
http://www.roverparts.com/Parts/9985F.cfm
and do I really need this, i don't have a socket that big so I guess yes...
http://www.roverparts.com/Parts/606435.cfm
It's obviously not as easy as a DII huh?
Old Oct 8, 2009 | 09:25 AM
Josh, as far as hardware goes, that is what you want to do. Depending on the mileage of this truck, if high, you might consider a new bearing set instead of packing the old set.
Yes, you need that socket and a big breaker bar.
Looks like another fun day in the sun for you again.
Old Oct 8, 2009 | 09:49 AM
jycsalas's Avatar
The mileage is 130k...
Old Oct 8, 2009 | 10:26 AM
You are in that gray area, I would give the owner the option.
Old Oct 8, 2009 | 11:32 AM
antichrist's Avatar
Ditch the hub seals in the kit and use RTC3511's. The stock D1 hub seals are worse than useless.
Old Oct 8, 2009 | 11:37 AM
Tom,
How come, what have you found to be wrong with them?
Old Oct 8, 2009 | 12:52 PM
jycsalas's Avatar
Tom, I am sure you know exactly what you are talking about and I don't want to regret using the seals in the kit if they will not work. What's up with the new seal?
Old Oct 8, 2009 | 02:37 PM
antichrist's Avatar
Ok, I guess I was overly broad.
It's not that they don't work, they are designed to keep the lube in, but are pretty worthless at keeping contaminants out. I would only ever use them if the vehicle was never used off-road or in water over the hubs.
The RTC3511 is from the Defender (same hubs as a D1) and are double lipped and do an excellent job of sealing in both directions.
Some installation tips here:
http://www.d-90.com/forum/showpost.p...9&postcount=11
Old Oct 8, 2009 | 02:55 PM
Now that makes a lot of sense, glad you mentioned it.
Old Oct 8, 2009 | 03:06 PM
jycsalas's Avatar
Glad you mentioned it too, I ordered those seals about 2 hours ago. Im sure this will make this customer happy to know WE upgraded his seals...
