DI to DII axle swap
http://www.roverlandparts.com/1999-2...abssensor.aspx
80% of the time a leaking hub on a DII is a bad seal not the hub.
ORIGINAL: NiteTrain
my rear wheel seals appear to be developing a leak...$800 for hubs is not an option
you can narrow any axle
So how would you widen the axle? Not to mention that DI's have a full floating rear axle while DII's do not.
ORIGINAL: Spike555
If the oil is milky then yes you have water in there. Could be from a clogged axle breather or a bad seal somewhere, pinion or hub seal.
Change the diff fluid and then remove your axle breather and make sure that it is not clogged.
My rear axle breather was clogged when I bought my truck, the diff would build pressure and cause a leak at the pinion seal.
Replaced the axle breather and all is good.
you can make an axle wider with wheel spacers..not sure if anybody makes them for rovers..but the D1 axle is just one option...for $800 I could but a ford 9" / dana 44 combo...the coil buckets and perches and the lincoln 135 amp welder Ive been wanting
those hubs at rover land are used arent they? with my luck I would be in the same situation 2 months from now..but $400 poorer
Yes they are used, but also warrentied.
http://www.roverlandparts.com/1997-1...mbly-rear.aspx
http://www.roverlandparts.com/1999-2...mbly-rear.aspx
I just do not think that buying a used axle, and Jerry rigging it to fit will save you any money.
Dont forget that the DII and DI use a different ABS system, so your 3 amigos will be on all the time.
