Are DI & DII Winshields the same?
Old Mar 13, 2020 | 07:41 PM
DiscoID's Avatar
Default Are DI & DII Winshields the same?
Anyone know if the front windshield (non-heated) on a DI and a DII are the same, or interchangeable? I have an '03 DII with a crack in the windshield and need to replace it. There are a couple of DI's and earlier model year DII's being parted out within a few hours drive, but wasn't sure of the exact spec on different model years?
My other option is to try using Safelite AutoGlass and hope they can find the correct replacement, but that's looking like it might be pretty expensive.
Old Mar 13, 2020 | 09:43 PM
Dave03S's Avatar
I'd take an original LR windscreen over the Chinese replacement the insurance company will let you get. The knock off's don't take rock hits as well as the OG glass did. They would be farther ahead paying the G for the Pilkington windshield rather than five $450 pieces of soft glass.
If you can pick a good condition OG windscreen DO IT!
Old Mar 14, 2020 | 07:54 AM
Best4x4's Avatar
If I'm not mistaken the D1 windshield is shorter vs a D2. As far as cheap glass goes I agree that Pilkington glass is excellent. However I'm pretty sure the glass Safelite uses isn't that super thin crap from China. I've had several company windshields replaced there (multiple vehicles) and they held up fine to the debris tossed at me out on the highway. IMHO I'd be more concerned with the quality of the install itself!!!! You can have the $$$$$ glass in the world, but if it's put in crappy you'll have water leaking into your LR and eventually you will have a rusted out bulkhead/floor.....
Old Mar 14, 2020 | 10:51 AM
DiscoID's Avatar
Best4x4 - Thanks for the input. I'm not 100% confident in the install by Safelite, but not sure how many other options I'll have in my area. Trying to do as much research and gather opinions/experiences from others before I pull the trigger. The crack in my windshield is about half-way across, so I'll need to do something soon.
Old Mar 14, 2020 | 02:10 PM
PalmettoDisco's Avatar
Another D2 will work, but D1 body is 4 inches narrower, so very doubtful on D1 glass. If you find a used heated glass, you have a prewired plug for it. Search on here for install. I think a plug is preexisting for a switch in the cabin. If it is already out of the previous vehicle, you can set in front of your current windshield and plug in and check the heating elements with a digital thermometer (need to temporarily borrow a another switch to turn on). Then decide if good enough and price.
Old Mar 14, 2020 | 04:38 PM
OverRover's Avatar
No matter heated or not the DI windscreen won't fit in a DII.
DI Unheated: AWR2228 Heated: AWR3282
DII Unheated: CMB101040 Heated: CMB000300
Old Mar 14, 2020 | 04:41 PM
DiscoID's Avatar
PalmettoDisco & OverRover - Thanks for the info!
The DI windshield that I had a line on has a crack at the passenger base anyway. The hunt continues.
Old Mar 14, 2020 | 04:51 PM
Brandon318's Avatar
I just had a Safelite windshield install done on one of my D2s and it's excellent. The brand is that same company that's in that Netflix doc American Factory... Fuyao? They make glass for pretty much every carmaker it seems. It's heated, works great, came with a new OEM seal for the top of the glass too. $632.11 was the total. No leaks and it's been installed for about 6 months.
Old Mar 14, 2020 | 05:05 PM
DiscoID's Avatar
Brandon318 - Thanks for that report. I don't think I'm going to go with the heated option unless I can find a used one (working) at an affordable price, but it's great to know that you had a good experience with Safelite. Also great to know that it included an OEM seal!
Old Mar 14, 2020 | 05:37 PM
mln01's Avatar
FWIW, Safelite replaced the wind screen in my DII 10 years ago this summer and did a great job. Pilkington glass. No leaks, and no A-pillar trim broken. I have no idea whether or not you'd still get Pilkington glass from Safelite but you can ask.
