Are DI & DII Winshields the same?
Brandon318 - I had thought about doing some of the disassembly/prep myself if I have Safelite do the replacement. Trouble is their facility is about an hour away here in North Idaho, so might have to opt for their "come to you" service and pay a little more to ensure nothing gets broken.
Curious about removing the battery cover? The previous owner of my Disco broke one of the tabs and the turn-**** barely catches at the front of the cover, but it's still there along with the jack and wheel chock. I guess I should call that part lucky.
Also, my windshield cowl is cracked on the ends near the hood hinges, missing the rubber end pieces, and also missing the "foam" which is a dust guard I believe? I'm hoping to be able to find a replacement that's complete, or in better shape at least, but will need to find a more affordable used option if I can.
Anyone have some ideas?
Every glass shop I've ever used broke the clips on the exterior A pillar trim. They ended up buying new A Pillars from the dealer too. If you can remove those without breaking them then I would do that at the least.
I assume you must be around Moscow to be an hour south of Safelite... I have family in that area too, Welcome to the forum!!
DiscoID (03-15-2020)
