Diagnosing ACE Amber light + Flushing the ACE Fluid
So, I have an amber error of the ACE system and would like to have a go at fixing it. Nanocom returned the following:
(40) Sensor supply signal out of range
(44) Battery voltage too low (main supplty voltage out of range for 614 seconds) - not sure why, battery is in fact good.
(Masked fault) (48) Main relay test has failed
I have slight leaks from the actual actuators and a very slightly leaking valve block, so those are the first things i guess. Will I need a nanocom to replace those things to be able to properly flush and bleed the system? Doubt is has proper ace fluid in there so I would flush it even if I do not fix all the leaks right away, just to protect the system from further problems
Also, to fix the leaking valve block, do I need a new valve block or can I get away with a seal kit (RVW100010). It is leaking from the pipes going into the block from the engine side.
let me know
Mark
let me know
Mark
Same issue !
let me know
Mark
let me know
Mark
ACE system - what fun!
This is what I did to fix my leaky valve block:
https://landroverforums.com/forum/di...pgrade-101442/
I had the same problem, except my ACE light would go to red and blink with a chime. It would continue until I shut off the engine, waiting a few seconds and restarted. It would do this when waiting in traffic jams, stop and go type driving. I had a leak in the block, due to corrosion of the aluminum according to a local LR indy shop. So led it all with this a rebuild, redesigned ACE block from Design and Development Engineering, Ltd. https://www.designdevelopmenteng.co.uk/.
installed easily, and comes with new valves, filter and sensors. Works great!
Rebuilt ACE block
Rebuilt ACE block
i forgot what the fix for that particular problem was but at the end i replaced all the hoses and fitted standard bsp fittings to solve the leak, changed the ecu to fix an intermittent amber light and then i also needed a new transducer as i had an intermittent red light. i suspect the out of range issue was the transducer
