Diagnostic tools... best bang for the buck
#21
Some of the Brits here have been raving about the Autel AP200 app and Bluetooth OBD dongle for $70-ish. From reading the website, it looks like this AP200 app mimics there costly handheld Autel MaxiCOM MK808 Diagnostic Tool at $450.
Some of the LR3/Discovery 3 owners have stated they used this to sync new key fobs unlike the Foxwell that can not do this...
[Multi-Language] Autel MaxiAP AP200 Bluetooth OBD2 Code Reader with Full Systems Diagnoses
PDF Manual... https://autel.com/u/cms/www/201910/30032935vzl0.pdf
I might pull the trigger on this one....
#22
Were I to do it again I'd probably spend a few extra dollars on a better dongle. Some don't sleep when the vehicle is off and can drain the battery. I have to remove mine each time I'm done using it.
robertf reports that this particular dongle will work with his GEMS reset tool (for you D1 owners).
#24
I can't really recommend the Foxwell that I got (NT650) as anything all that special. It has deeper functions for some manufacturers and vehicles, but its specialty options for Rovers seems pretty limited. Can't change adaptive settings, for example. There are other devices that do just as much on a Rover for less money.
#25
Foxwell NT520 Land Rover Discovery II review: worth buying | Foxwell Support Blog
#27
What adaptive settings did you have in mind? I have 520 and it resets most of the of stuff that I require... Some highlights are here:
#29
