Did I just do a dumb thing?
Old Jul 27, 2021 | 05:29 PM
Brandon318's Avatar
Default Did I just do a dumb thing?
Put the speedy sleeve on the harmonic balancer, went on like a charm…but the brass shield thing…I didn’t even think about this. Am
I screwed?
Old Jul 27, 2021 | 05:46 PM
dswilly's Avatar
Guessing here but that might be a debri shield and nothing more. When you put the speedsleev on did you check it to cover the groove? Looks like you did. I know on mine I needed to measure that I did not seat it down too far or it would have missed the groove or seal line,
Old Jul 27, 2021 | 06:26 PM
Brandon318's Avatar
Amazingly the sleeve perfectly fit the exact groove. Really amazed by this thing.
And yeah, the brass thing is a debris shield, but its still needed to protect the crankshaft seal yeah?
I was contemplating filing off the lip of the speedy sleeve just enough to fit the debris shield. Thoughts?
Old Jul 27, 2021 | 06:33 PM
Extinct's Avatar
Does the debris shield fit over the sleeve? If so the flange on the speedi sleeve is designed to be cut off.
Old Jul 27, 2021 | 06:51 PM
Discorama's Avatar
Old Jul 27, 2021 | 06:52 PM
Brandon318's Avatar
Yep, it does fit over the sleeve, with clearance.
I didn’t realize the flange gets cut off, that’s solves everything. Any best way to do that?
Old Jul 27, 2021 | 07:03 PM
Brandon318's Avatar
Solved… snip the flange. Tear off. There’s a wee tear-off groove machined into the surface.
Old Jul 27, 2021 | 08:00 PM
Brandon318's Avatar
This product is amazing. Super rare that something that costs $40 so effectively saves $800.
Old Jul 27, 2021 | 08:08 PM
dswilly's Avatar
Well done. Mine stopped a solid leak cold.
Old Jul 27, 2021 | 08:09 PM
Brandon318's Avatar
Worked out so well I preventatively ordered another one for the eventuality I'll need one for the 2004. Who knows how long these will be around for.
