Did I overfill my oil?? Help please.
Old Oct 4, 2009 | 04:00 PM
oysterhead's Avatar
Default Did I overfill my oil?? Help please.
This is the 1st time changing my oil...I guess I overfilled it, see the picture.
My steps:
1. Drained oil until no more was dripping out, reinserted plug.
2. Removed old filter, partially filled new oil filter, and inserted.
3. Put in a total of 5.75 quarts (including amount in filter).
4. Ran engine, revved it.
But the oil line is WAY over the fill point. What gives?
The only thing I can think I did wrong was the truck was not warm. I had moved it from the driveway into the garage about an hour earlier.
Also, the oil on the dipstick got way darker after I revved the engine. Is that NORMAL?
Should I pull the drain plug or what?
p.s. I used Mobil 1 oil and a 301-1 filter. (1st time block has seen synthetic)
Old Oct 4, 2009 | 04:50 PM
With a 301 filter you will actually use 6 quarts of oil. Not sure what you did wrong, but I would do a drain and refill, no new filter and fill it based on the dip stick reading.
The fact that it go blacker after you reveved it tells me you didn't get all the old oil out.
Old Oct 4, 2009 | 04:51 PM
oysterhead's Avatar
damn, a $30 mistake.
fu@@K.
Old Oct 4, 2009 | 05:41 PM
david1289's Avatar
Are you sure you pulled the OIL drain plug and not the tranny plug? Seen people make that mistake before on other kinds of cars (particularly Mazda front wheel drive cars...the bolts looked the same...had to pay attention on those).
Old Oct 4, 2009 | 07:41 PM
Disco_Fever's Avatar
Not sure how many people really follow the procedure to the "T", but Land Rover states that you are to drain the oil, then refill the oil to full as indicated on the dipstick. THEN, remove the oil filter and install new filter. 2 separate procedures, done in sequence. I also fill the new filter about half-full and oil the gasket at the top before spinning it on.
Just FYI. Out of curiosity, how many people were actually aware of this and follow the procedure as outlined in the RAVE manual?
Old Oct 4, 2009 | 07:51 PM
lipadj46's Avatar
It does not matter but no I don't think people usually do it in that order.
To the OP how far over the full line are you? Did you warm up the oil first? There is a big difference in how much oil you get out depending if the oil is cold or warm. You get out about a quart more out when hot. If you drained out hot oil then 5.75 quarts is correct. Do yourself a favor read the dipstick in the morning when cold or after the truck has sat for a few hours, after the first couple tries the oil gets up in the dip stick tube and gets hard to read properly.
Old Oct 4, 2009 | 08:47 PM
oysterhead's Avatar
bingo. i'm a freakin idiot.
good news: i have now have fresh tranny and motor oil.
i'm at 52k, so it was almost time for gear oil anyway.
hey, live and learn. ran the truck hard down the road. everything seems fine. no leaks, etc.
AT LEAST I DIDNT POUR ATF IN THE MOTOR OR VICE VERSA! hah.
Old Oct 4, 2009 | 08:55 PM
brianb883's Avatar
Good thing you caught it, that could have been catastrophic if you had decided to drive down the street....
Old Oct 4, 2009 | 08:57 PM
oysterhead's Avatar
man, my heart sank when i pulled the plug to re-drain the "motor oil" and nothing came out. i immediately knew what i had done.
i only ran the truck for about 30 seconds, in park the whole time. hopefully no damage.
but, yep, that's me. i always seem to be teetering on catastrophe.
Old Oct 4, 2009 | 09:01 PM
You're safe.
